Soyachips’ Electric FZR250
soyachips
Real Name: Andrew Lo
Re: Soyachips’ Electric FZR250
Post by soyachips » Thu, 30 May 2019, 21:56
Also put together a test battery pack using 24 x 15ah Headway cells to do some bench testing.
soyachips
Post by soyachips » Thu, 30 May 2019, 22:18
I struggled trying to get the controller to do the angle identification setup and control the motor but got there in the end. I did swap the positions of the hall sensor A and C wires in the connector so they matched the controller connector side. That didn't seem to fix it straight away but after running the setup step and few more times it eventually worked. Whenever the angle identification setup finishes it puts out a buzzer alarm code 3,2 which is for internal reset which isn't very intuitive. It might have been working a bit earlier as I didn't test the throttle every time it finished, thinking it hadn't worked because of the alarm!
soyachips
Post by soyachips » Thu, 30 May 2019, 22:33
One problem I've run into is the gap between the brake rotor and the motor is pretty small so the original brake caliper doesn't fit!
I contacted QS Motor and they recommended a few from their catalog that would work. Ended up getting this one in grey. I'll need to get a new mounting bracket made based on the original design and this new caliper.
francisco.shi
Real Name: Francisco
Post by francisco.shi » Fri, 31 May 2019, 07:32
What is the energy density of the finished battery pack? (Wh/kg)
soyachips
Post by soyachips » Fri, 31 May 2019, 09:38
According to the specs, the Headway 15ah are 105 Wh/kg
francisco.shi
Post by francisco.shi » Fri, 31 May 2019, 10:50
Is that after it is assembled with the bus bars and holder?
soyachips
Post by soyachips » Fri, 31 May 2019, 17:51
No that’s just based on the specs of the cells. This is just a temporary pack that I’m using for testing. Still haven’t decided exactly what the final pack will be.
soyachips
Post by soyachips » Mon, 10 Jun 2019, 20:40
Had some awesome help from Danny Ripperton (AEVA member) machining the swingarm blocks that hold the hub motor axle.
The blocks are solid aluminium and weigh 344g each
soyachips
Post by soyachips » Mon, 10 Jun 2019, 20:48
Put the new blocks into the existing swingarm, swapped the tyre over and got it all into the bike. Next step is to work out how to mount the batteries and controller inside the frame. Decided to push the bike home from the workshop and got some interesting shots on the way :D
AudibleDestrcution
Real Name: Jake
Post by AudibleDestrcution » Tue, 20 Aug 2019, 18:47
soyachips wrote:
Tue, 23 Apr 2019, 21:47
I'm a bit late to the party for this, but I'm a stickler for data so I couldn't help but mention it.
The continuous discharge for yinlong cells is rated at 10c, and the burst is 25c from memory.
I saw yinlong has 150 as continuous, which is nearly a third of whats it capable of.
I considered that it might be referencing a minimum voltage you have specified for your needs, but the others seem to be rather high for that.
Im an avid user of yinlong so i thought id just point it out.
Post by Richo » Wed, 21 Aug 2019, 12:37
The link I provided indicated 6C/15C by the seller.
So the data soyachips used was based on that.
I understand that this is your experience but is there any actual tests or datasheets that claim 10C/25C?
In anycase I doubt that it was deciding factor for the battery used in this conversion.
