PIP-5048MK inverter
affer
Re: PIP-5048MK inverter
Post by affer »
Sun is starting to produce power again.. here is my on and off-grid systems.. it might be an eastern project to put on more load :-D
Screenshot 2020-03-26 at 19.23.39.png (175.57 KiB) Viewed 57 times
jannie
Real Name: Jan Hough
Post by jannie »
XtractorFan wrote:
Wed, 25 Mar 2020, 18:37
I am a bit afraid to venture into ICC or similar
ICC and SolPipLog (the one I use) connects via USB (or serial)....
I noticed your com port is 8 - using CH340 have you tried changing its properties to use a lower port number?
My logging PC is quite old and has a 'proper' com port set as com1 for WathPower - if I need to use it.....
I initially had problems using USB/Serial adapters.
Thanks for your thoughts. I did try with the direct serial cable to my old laptop and port COM 1. The serial info is coming through as recorded my my 'Serial Port Monitor' program, but WatchPower is dead. :cry:
jannie
Post by jannie »
fllniks wrote:
Thu, 26 Mar 2020, 21:41
jannie wrote:
Wed, 25 Mar 2020, 06:14
It is working fine, but I am having a huge problem with WatchPower on my PC connecting to the inverter. When I do see serial communications (tested with Serial Port Monitor) the WatchPower program does not record any data. Can anyone give me a suggestion as to what to do next?
Try to following and see if it helps. I have noticed often watchpower won't record data if not run as administrator.
Close watchpower and make sure to exit it from taskbar too. Then right click watchpower and click "Run as administrator". Now, check if it is recording data or not.
Thanks for the advice. I have been doing just that. Still no joy. :cry:
paulvk
Post by paulvk »
jannie
Have you set the baud rate in windows advanced settings to 2400 ?
jannie
Post by jannie »
paulvk wrote:
Yesterday, 06:03
jannie
I had the baud rate at 9600 because I had seen that value somewhere (can't remember where). I changed it to 2400. No difference. :cry:
jannie wrote:
Yesterday, 17:33
The main part of firmware updates happens at 9600 bps, although the initial negotiations are at 2400 bps.
Watchpower should be setting the bit rate; no need for the user to do this.
affer
Post by affer »
my 5048mk is stucked in the read outs at the moment.
https://www.pvoutput.org/intraday.jsp?i ... t=20200329
it reads the same from the serial port even that that the sun has gone down. i use solpiplog for reading out, and nothing have changed in a few hours.
i can send commands to the MK, and it reports back firmware etc..
i am not able to get to the unit itself until at least after the 6. of april,
is there i command i can send to any one knows if it is possible to reboot the serial board, og i can do anything else remotely to get the issue fixed.
ive already rebooted the pi that interfaces to the MK
btw, it seems that i also had a dip today.
