HOW LARGE CAN I CHARGE?
Technical discussion for the Blade
Randall679
Real Name: Randall Berger
Post by Randall679 »
My 2008 Blade Electron is basically a Model T EV. Can some clever clogs tell my how high I can go with a charger? If it has a Type 1 connection ... J1772 ... will my battery management system handle it? I mean, a wall plug is the base line ... 10 - 15 amps ... but can I plug into the system at Euroa and not blow the bonnet off? Type 1, type 2, 16A or 32A. It's a bit confusing ...
Real Name: Richard Baird
Re: HOW LARGE CAN I CHARGE?
Post by reecho »
Randall679 wrote:
Thu, 25 Oct 2018, 19:21
Yes a j1772 AC charger will work fine providing you have the proper socket and associated control circuits in the Blade.
No you cant use the DC fast chargers without some heavy investment
Agreed. J1772 is AC charging, so it uses the same charger inside your Blade that you use when charging at home. Your bonnet will be safe :)
Randall679
Yes, the charge socket on the EV is a J1772 ... Type 1 ... I also have a Type 1 to Type 2 adapter and a Phase 3 step down to Phase 1 adapter. I'm becoming a Boy Scout late in life ... I'm also thinking about putting an EV bowser on the solar house ... maybe a Cylon, because I was a big BG fan. I believe these charge at a higher rate ...
Bryce
Real Name: Bryce Gaton
Post by Bryce »
Hi there - your Blade possibly won't work with Mode 3 EVSEs (i.e. the fixed wall box AC ones) as they communicate with the car to allow charging. Is an easy fix if it won't though. Cheers Bryce
AEVA Vic Branch Secretary
Current EV drives: Kona electric, 2001 Berlingo conversion
Selling: 2011 Leaf
Past drive: 2011 Blade Getz
Randall679
Bryce wrote:
Sat, 27 Oct 2018, 07:08
Which wall box would you suggest?
Bryce
Post by Bryce »
Hi there-it's not the wallbox you need-it's some electronics you need to add to the car to convince any wallbox to turn on. Search for 'modular EV power AVC2'. You just add it to your car J1772 inlet socket and you are good to go for any AC EVSE. I have it on my Berlingo conversion and it works well.
Cheers Bryce
Selling: 2011 Leaf
Bryce wrote:
Mon, 29 Oct 2018, 18:05
I've seen this on a recent Blade. If the car has a J1772 socket, I assume that it would have the ACV2 gizmo to make it work on any type 1 (J1772) EVSE. [ Edit: or indeed, other EVSEs with the appropriate adapter. ]
Bryce
Post by Bryce »
Not a safe assumption. My mk5 Blade had a J1772 but did not charge on EVSEs. The one I am working on now plus last one I fixed both do. (Those were both 'upgraded' versions. Mine was an early fitted J1772 version). Easy to test, try it on either a portable or wall mount EVSE! Cheers Bryce
Selling: 2011 Leaf
Randall679
This is the charger for my 2008 Blade ... It's a Lear Voltec ...
2018-10-31 08.44.29.jpg (138.25 KiB) Viewed 1875 times
2018-10-31 08.43.53 HDR.jpg (121.03 KiB) Viewed 1875 times
2018-10-31 08.44.04 HDR.jpg (99.96 KiB) Viewed 1875 times
Bryce
Post by Bryce »
In that case, yours has the electronics. ☺ It will talk the EVSE into turning on and pull from the wall EVSE whatever the charger is set for. (Blades never pull much, so the chances of it exceeding the EVSE settings and confusing things are pretty close to nill). Cheers Bryce
Selling: 2011 Leaf
