Single phase charging
Renault EV Interest Group
doggy
Real Name: David Kerr
Post by doggy » Tue, 30 Apr 2019, 14:19
Three phase charging of Zoe at 22kW is pretty good. Typically, as long as the SOC is 80% or below, I get 20.7kW into the battery at the DC level. So, 94% or better.
Here are some single phase figures I have just measured on my Zoe at 75% SOC:
Pilot=32A. Actual=32A. Power at meter box=7.6kW. Power at EVSE input=7.35kW. Power to 12V battery=100W. Power to HVbat=6.5kW (377V 17.3A). Efficiency=90%
Pilot=20A. Actual=20A. Power at meter box=4.89kW. Power at EVSE input=4.75kW. Power to 12V battery=60W. Power to HVbat=4.05kW (374.5v 10.8a). Efficiency=86%
Pilot=10A. Actual=9A. Power at meter box=2.12kW. Power at EVSE input=2.04kW. Power to 12V battery=50W. Power to HVbat=1.61kW (375V 4.3A). Efficiency=81%
Pilot=6A. Actual=6A. Power at meter box=1.11W. Power at EVSE input=1.06kW. Power to 12V battery=50W. Power to HVbat=0.56kW (375V 1.5A). Efficiency=55%
Several points:
a. I have corrected for power to the 12V battery. This could be significant at low charging currents if accessories have been in use.
b. If the aircon has to run to cool the battery, you have zero left at 6A as it will use between 500 and 1000W.
c. Powers are measured with a 1% accuracy power meter, so reactance and power factor are taken care of. Power factor is somewhat below 1 between 6 and 10amps
d. If we turn the above figures upside down and calculate how much power we actually need to add 32kW from 0% to 80% SOC we get the following:
32A three phase. 34kWhrs. Wastage=2kWhrs
32A single phase. 35.7kWhrs. Wastage= 3.7kWhrs
20A single phase. 37.2kWhrs. Wastage= 5.2kWhrs.
10A single phase. 39.5kWhrs. Wastage= 7.5kWhrs.
6A single phase. 58.2kWhrs. Wastage = 26.2kWhrs
I did these measurements to see if it was worth my while storing excess solar into a 12kW lithium battery at times when there was not enough excess solar for efficient Zoe charging and then dumping it into Zoe at a constant 20A through a 5kW inverter. This would also allow timeshifting as Zoe is often out when the sun is at its best. It all depends upon the round-trip efficiency of excess-solar->battery->inverter->Zoe and at the moment it looks possibly not worthwhile. Though it would improve the feel-good situation further.....still thinking about it....
Re: Single phase charging
Post by antiscab » Wed, 01 May 2019, 08:01
There is value in having home storage beyond charging the zoe more efficiently. Do you have time of use power? Not using power in peak periods there's likely to be some savings.
Are you export limited to 5kw? I'd be super tempted to put up more Solar, so there's more time where the surplus is above 6A, and simultaneously set the Zappi to minimum 10A charge and Max import 4A
doggy
Post by doggy » Wed, 01 May 2019, 09:22
Hi Matt, I am in a very treed area. So the solar varies a lot with shade hitting panels. That is why I have an Enphase system (which is working well). I already have 5kWhr of Calbs (24V) which I use to flatten out the day and it runs all computers, modems, servers, CCTV etc in the house pretty much 24/7 (we are a very compute-intensive house!) Yes, I can and do set the OpenEVSE to min 10A. I have no limit on the export other than 20c/kWHr for the first 170kWHr/month thence 10c. But I am about to change to someone else with a flat 12.5c/kWhr.
I probably will proceed with the 5kW inverter- I just need to get the right one. I have previously designed and built a 2.8kW unit but would rather not expend the time and energy this time.
LouB
Real Name: Lou
Post by LouB » Wed, 01 May 2019, 13:02
Hi Dave
As Matt says, it all seems to depend on how much power you have available. At our place, we seem to be blessed with more solar than we actually need. Even after charging a house battery, more than than 1/3 is going back into the grid. It accrues credits that we will probably never get back. This good performance from solar is not due to clever design but totally to happy accident. The part of the roof with the PV panels faces North, the roof slope is greater than 20°, and there is never any shading. It means that we have been able to adopt a fairly lazy attitude to charging Zoe and/or conserving power.
I also agree with Matt that more solar, and possibly more storage is the way to go. Also, if the trees are yours, it is not environmentally irresponsible to prune them a little to reduce shading.
doggy
Post by doggy » Wed, 01 May 2019, 13:25
Hi Lou,
Thanks. 60-70 metre Pittwater gums are not easy or cheap to prune!
Hm, I do not think I would like solar credits. We get 20c/kWhr atraight off the power bill.
I am stuck with shade and suboptimal direction (azimuth 70deg, tilt 23deg ). It only became practical & moderately cost effective to install solar last year and then only because of one inverter per panel. Even though a 4.3kW system, solar provided 80% of all power used plus fully charged Zoe (except for 2 interstate trips) over an 8 month period. Most of my electronics run off 24V or 12V and my 5kW 24V battery has proved very effective. We have also exported 600kWHrs since January 1 this year. I have also done a huge amount over the past 5yrs to cut home power usage. I even built my own solar HWS (using 36 evac tubes). Hot water costs me less than $10 per annum. Offpeak boost has been 2.2kW in the past 8 months and that system had paid for itself three years ago.
Anyway, the real purpose of this thread was to give Zoe owners a good feel for the Chameleon charger efficiency. Overall, given it has to cover from 6A 240V to 32A three phase, it does a pretty good job (methinks).
Post by antiscab » Sat, 19 Oct 2019, 11:34
I did some charge testing last night. All values are reported by the car, though I did have my clamp meter inside the charge station to do a sanity check on values.
The 3-phase 6A charging looked interesting, I might have to redo that measurement - it looks like the car was actually exporting power in order to observe the current limit.
					Meas(A) Pilot  AC(kW)	AC(kVA)	PF	Bat(V)	Bat(A) 	Bat(kW)	Eff	12v(W)	12v(V)	12v(A)
					32.0	32.0	7.35	.	.	377	17.3	6.50	90%	100
					20.0	20.0	4.75	.	.	374.5	10.8	4.05	86%	60
					9.0	10.0	2.04	.	.	375	4.3	1.61	81%	50
		AC (V)			6.0	6.0	1.06	.	.	375	1.5	0.56	55%	50
phase3	phase2	phase1	phase3	phase2	phase1	.	.	.	.	.	.	.	.	.	.	.
		237			9.3	10.0	2.02	2.20	0.92	359.5	4.8	1.73	85%	47	13.3	3.5
		238			16.6	16.0	3.69	3.81	0.97	358	9.3	3.33	90%	40	13.4	3
425.5	409	416	15.1	15.4	15.7	16.0	10.28	11.12	0.92	361	26.3	9.49	92%	47	13.3	3.5
428	412	416	12.5	12.7	12.8	13.0	7.93	9.18	0.86	359	20.3	7.29	92%	53	13.3	4
425.5	414	417.5	8.9	9.1	9.3	10.0	5	6.60	0.76	358.5	12.5	4.48	90%	47	13.4	3.5
423.5	419	420	6.1	6.1	6.1	6.0	-0.389	4.45	-0.09	357.5	-0.5	-0.18	46%	53	13.3	4
The above table didn't copy from my spreadsheet all that well, so I've attached the original
zoe charging.xlsx
Clearly charging slow is best done on single phase
doggy
Post by doggy » Sat, 19 Oct 2019, 13:54
Hi Matt,
Those figures agree closely with my experience.
However the 6A three phase ones are definitely odd. I'm wondering if the heat pump was running to condition the battery? Heat pump can draw over 3kW and it runs directly off the traction battery.
Since my original post, I did implement two Lithium batteries, both tracking excess solar. I frequently dump the bigger one (8*AVASS 460AH cells) into the Zoe if she has been out during the high insolation part of the day. At 15 to 18A single phase, I get the best result. Inverter efficiency about 91-93% and Zoe charge efficiency about 85%. Battery charge efficiency about 95% depending upon charging current (best 98% at max). I get about 21% into Zoe per charge from the AVASS batteries. I cycle them about 410AH of the notional 460AH.
My system decides to stop charging the batteries if the return drops below what I get from FIT.
I run OpenEVSE at about 18A single phase with minimum 10A if Zoe is home during the day. So OpenEVSE tracks the solar.
Here is a chart showing the excess solar tracking using my two chargers and lithium batteries. Yellow is solar input. Blue is usage. Usage in this case was breadmaker, fridge, waterbed, making coffee, all computers etc etc. The first battery is 8*CALB180 and charges from 2 up to 38amps. When there is excess solar beyond that plus other usage, the second one kicks in. It does 2 to 58A. Also, the first battery automatically kicks in to supply all my computers, switches, modems, 8CCTV cameras, servers etc. So typically they run off the battery until there is enough sun, then they switch back to mains power and then when the insolation increases, the first charger kicks in. All the computer gear runs off 24V and I pensioned off over three dozen power adaptors.
Screenshot from 2019-10-19 16-43-56.png (42.64 KiB) Viewed 301 times
Post by coulomb » Sat, 19 Oct 2019, 17:50
Does it do that standard, or did you have to write some of your own software?
doggy
Post by doggy » Sun, 20 Oct 2019, 04:50
OpenEVSE needs no extra software. As standard it can track extra solar. However, I did need to write a Python script which extracts data from the Enphase Envoy (controller for the microInverters) and make it available through MQTT.
I DID have to write heaps of software for my two lithium chargers, BMSs etc.
Post by antiscab » Sun, 20 Oct 2019, 09:23
What did you load the python script into?
doggy
Post by doggy » Sun, 20 Oct 2019, 09:48
The python script runs on a reliable low power Linux server which also hosts my email, file storage for the house, CCTV footage etc. This server runs on 12V using OpenUPS power supplies and a low power Motherboard/CPU and ZFS disk array. However, the python script could run on anything as I also have a number of Odroids and Beaglebone Blacks around the place any of which would be fine. The latter run things like my Weather Station, Media Servers, Backups of the Backups.... The Python script is an undemanding chunk of code which runs every 10secs....Thus OpenEVSE and also my two Lithium systems run on the same MQTT data which is posted every 10 seconds. This system runs very reliably for at least a year at a time without needing to be rebooted.
Incidentally, the two Lithium chargers/controllers are PIC based each having one overall PIC controller and a dedicated PIC driving each Buck Converter. I use an Onion Omega2 to provide the user interface because they are powerful, cheap as dirt, reliable and have WiFi and direct Ethernet. However, I only use the WiFi and they talk to the PICs via serial. So my Lithium chargers are online and I can access them from anywhere in the world.
Overall, the python script was first and I needed that so that OpenEVSE could track excess solar. Then when I decided to build the first Lithium battery and control/BMS stuff, that project grew bigger and bigger and consumed a lot of time and effort. The second, bigger Lithium setup was way quicker and I only did it because I had the good fortune to buy 8 AVASS cells. I was able to reuse all the previous effort.
So now, it is all finished. It would have been nice to have all this integrated into a new-build house, but I have had to make do with a 40yr old house and things grafted into it rather than having a master ATS on the switchboard and the ability to run the whole house on the big battery. Instead, I use the big battery for EV charging, running Aircons and as a backup when the Grid fails (as it does more often). 5kVA (15kVA peak) is enough to run the garage, microwave, kettle, some lighting, aircon, EV charging. But I have to manually switch things over when the grid fails.
The smaller battery is running all the IT stuff and does this from Solar for a very large percentage of the year (it is prioritised over the AVASS battery). It is all automated (i.e. it decides when to switch to battery power, when to switch off from battery to mains, when to charge and the tracking.
