EOI - New Yinlong LTO cells Australia
- Real Name: Chris
Re: EOI - New Yinlong LTO cells Australia
So to work it out, at a 2.4v 55Ah battery
I need 96v
So my series pack would be 40 Cells
Now I want 180kWh, or alternatively, 1,875Ah
So if each pack is 96v, 55Ah of a Series pack, I need 35 Packs (Which nominally gets me above my threshold at 1,925Ah or 184.8 kWh
As for weight, they are 1.9kg each from what I can gather, so that's:
80kg per series pack
2,800kg for 185kWh
This makes for a really heavy pack.
I mean, I'm interested, but is there a better unitised pack available?
I need 96v
2,800kg for 185kWh
- Richo
LTO's are for PERFORMANCE
Small pack - high output
Any rubbish cell that does 1C will still do 180kWif you have 180kWh.
- Real Name: Jordan
There are many battery types with better energy density such as LFP and NMC but the trade off is much shorter life expectancy.
- Real Name: Jake
There is a very strong interest for these cells in the car audio community, there's already been a bulk of about $15000 of the 34 ah yinlong cells.
If someone imported a bunch in and they were a reasonable price they'd sell easily, the high discharge and inherent cell voltage plus safety makes them perfect for the thousands of amps that car audio setups needs at 14 volts.
A company in the USA has started buying thousands directly from yinlong but shipping from there would be a bit average.
There isn't a huge demand for them in australia yet as a lot of people have had their head in the sand, I was the possibly the first person In Australia to discover these in the car audio community mid last year (2018)
I've got 120 35ah myself and they are fantastic, good for 7000 amps at 13v+ which is plenty.
People are slowly releasing these are absolutely superior to the garbage agm batteries everyone's been using since the beginning of time.
I should hope so! 13 V x 7000 A = 91 kW. How does a voice coil or even several of them stand that sort of power level even instantaneously?AudibleDestrcution wrote: ↑Sat, 08 Jun 2019, 11:57... car audio community...
... good for 7000 amps at 13v+ which is plenty.
Disclaimer: I'm not part of the car audio community, so I'd be the first to admit that I don't understand it. I would think that 100 W RMS per channel would be really, really loud in a car, so say 1 kW peak (wild guess). What am I missing?
Ah. More than a "few" voice coils. And lots of fans to cool them.
And competition for the most outrageous, rather than a usable system for actual listening. I guess it's a hobby. A very expensive one, I suspect.
Thanks, @brendon_m, for the education.
- Richo
Ah so I approached the problem from the other way.AudibleDestrcution wrote: ↑Sat, 08 Jun 2019, 11:57the high discharge and inherent cell voltage plus safety makes them perfect for the thousands of amps that car audio setups needs at 14 volts.
If think about a 10kW 1R sub the first thing that happens in the amp is it boosts the 14V up to 100+ volts.
If your ev is already at 144-150V just bypass that stage and run from the traction pack of your ev direct.
- Richo
Nope it isn't.
Loud is when the front window flexes.
- Real Name: Jordan
Good Morning all,
40AH LTO cell stock is now in hand.
Retail price is $69.70 inc GST per cell.
Happy to talk wholesale pricing for anyone interested in larger quantities.
- Real Name: Jake
Most vehicles aren't made for competition, just for the listening/feeling pleasure.
Typically serious subs have 3" - 5" voice coils, ranging from 2000 - 5000w rms continuous power handling. The short duration power handling is up too 8000w rms and beyond for a single sub.
Usually the actual power the subs get combined as a total is 15-30kw, some exceptions with many subs or unusual setups might be 40kw+. even 60kw of actual applied power, not potential power.
The normal mid and high freq speakers aren't taken into consideration as the power they require is comparably insignificant.
Loud is when you cant breathe, the windscreen breaks along with the a, b and c-pillar, i speak from experience haha.
It is silly, but so are alot of things, sure beats the danger of Motorsport though that's for sure, tinnitus generally can't kill you,
Ill spread the word that these cells are available, there's at least 2 people I know that want some and many more than need some but might not know it yet.
If you could advertise them on the facebook page "Melbourne Car Audio" that would be fantastic, along with pictures of cells in out of packaging.
I've already done load tests etc on yinlong lto so if anyone has any questions I'll make sure they're answered, batteries are something that has held back the hobby of car audio and LTO will help it proceed to something a bit better.
Baron, please can you pm me? I cannot message you for some reason? would like to discuss.BaronVonChickenPants wrote: ↑Wed, 12 Jun 2019, 09:07Good Morning all,
- Real Name: Jordan
Hi Mike
I tried but received the following message "Some users couldn’t be added as they do not have permission to read private messages."
You can contact me at www.coastalphones.com.au
- Real Name: Jake
@BaronVonChickenPants
Have you had a chance to put up any pics/advertising for the cells yet?
I'm interested in LTO cells, but as a noob, I'm concerned about putting a pack together without having cell holders. Are plastic cell holders available like those for headway cells?
- Real Name: Jordan
Th 66160 are a bit big for a plastic holder at 66mm diameter x 210mm total length including the M12 terminal posts.
We use Aluminium plate to build our packs, 3mm x 100mm for low current (less than 300 amps) 5s2p caravan batteries and 6mm x 100mm for 5s2p start batteries.
3mm x 50mm and 6mm x 50mm work well for 1p batteries.
- Real Name: Jake
The Russians use plywood as cell holders, most outside of Russia are just held together with cell links and put in cases.boxes,etc.
I've just got the linking plates holding my 700ah bank together (20p6s)
I'm looking at surrounding it with foam and a case to help distribute load evenly and avoid breaking any posts off in the long term.
Also @BaronVonChickenPants check your pm's please.
- Richo
I would have thought laser cut acrylic or jet cut polycarbonate would be ok.
Non-conductive too...
- Richo
