Pending further input from the brainstrust here, this would be a fairly sensible way to do it:
An off-grid setup: The PV array is set up as three panels in series, and as many of these in parallel as the roof (or budget) will allow.
Any more than two strings in parallel will call for in-line fuses on each array.
The isolator is a standard bit of kit. The MPPT solar charge controller manages the charging of a 48 volt battery. A good example is the Victron MPPT 150/100.
It comes with a LFP setting which sets the peak charge voltage at 57 volts and stops charging after that.
The load contactor is driven by the battery management system. If a cell goes out of spec (usually below 2.5 volts) the contactor will open. It will remain open until the voltage returns to within spec. The inverter is a separate bit of equipment which takes battery voltage and turns it into 230 V AC for the home.
It is possible to by inverters which both manage charge control and the inverter, but one thing living off-grid in my youth taught me, was that lights and refrigerator are well served by being on a DC supply. At least when the inverter craps out you can still find your way to the fridge to grab a beer
An example of such an inverter would be the MPP Solar PIP5048 inverter. It also has a 240 V AC input for the grid should you have it. This is where you use the grid as a generator, or an emergency fall-back. Or just to run the aircon. The 5048 doesn't push power back onto the grid (no export).
Any tips, changes, recommendations - feel free to chime in!
