TE Connectivity contactors
- jonescg
- Real Name: Chris Jones
Ever wished you could find a contactor small enough to do pre-charging or HV auxiliary switching but didn't want to fill a massive box up with needlessly large contactors?
Looks like TE Connectivity have some up with some pretty neat solutions.
http://www.te.com/global-en/products/re ... =pgp-story
- Richo
- Real Name: Richard
Re: TE Connectivity contactors
Most of the ppl I deal with use the TE part number 2203997-1.
And I'm not seeing any around.
Which doesn't say much since most TE relays are on like 60 week lead times.
I told TE to build a relay factory a year ago - really no joke.
I asked them last week why the problem is still on going since they have had a year to ramp up production.
They had no comment.
And add the cap shortage and nylon shortage and resistor shortage - tough times ahead...
Interesting tho.
I'll keep an eye out for some.
Interesting tho.
- Richo
OMRON has a possible alternative G9EA-1 12VDC.
But its not as compact.
Doesn't really seem any cheaper than the kilovac either.
- Richo
The TE contactor would have a loss of about 8W at 80A.
So considering an IGBT solid state switch with the same loss the voltage drop would have to be 0.1V which doesn't exist.
A FET solid state switch would have to have an on resistance of 1.2mR.
At 400+ volts that's a tough ask.
10-15 Fet's in parallel might do it but once again it would be bigger and cost about the same as the omron contactor.
- Richo
After a bit of searching around I also found that TE now also do a "precharge" conatactor.
But really it's just a low power contactor that COULD be used for precharge as it has a limit of 20A 450V.
Its called the "Mini K HV".
Model number V23700 and has a couple of variants.
Most of them seem to be around the $125 which isn't really worth it.
HOWEVER I did find one seller doing the V23700-C0001-A408 / 2-1904058-5 for about $25.
These are the PCB variant and are quite compact.
I'm interested in using a couple of these for precharge - suprise suprise...
At 150V 20A this is 3kW which is enough for the HV->12V DCDC converter (alternator).
- Richo
The datasheet for the EVC80 is dated 5/2018.
So it maybe that the product is too new to be picked up by suppliers.
So there is hope some might become available soon rather than the usual 50 week lead time...
- Richo
Omron also have a 25A 400V relay in the G9EJ series.
They are about $35ea.
There are blade quick connect in that series.
- Richo
So I ended up buying 5 of the mini-K contactor.
They were about $25ea.
Sad part was I decided I also wanted to isolate the charger from the pack when not charging.
And now I can't get the mini-K contactors for $25 anymore - they are more like $100+
So I had another look around for some more smaller relays:
FTR-J2AK012W
SPST-NO
450V 10A
$16.62
MKS1XT-10 DC12
SPST-NO
220V 10A
$25.06
G9EJ-1-DC12
SPST-NO
400V 15A
$40.73
G9EJ-1-E-UVD DC12
SPST-NO
400V 15A
$42.87
MKS1XTN-10 DC12
SPST-NO
220V 10A
$48.65
So it looks like the FTR-J2AK012W is the winner.
FTR-J2AK012W
SPST-NO
450V 10A
$16.62
MKS1XT-10 DC12
SPST-NO
220V 10A
$25.06
G9EJ-1-DC12
SPST-NO
400V 15A
$40.73
G9EJ-1-E-UVD DC12
SPST-NO
400V 15A
$42.87
MKS1XTN-10 DC12
SPST-NO
220V 10A
$48.65
- Richo
The above are proper DC relays.
Not regular relays that claim 200-300VDC under exceptional conditions.
- jonescg
You can see the magnetic blow-outs potted in the top corners of the unit.
- Richo
And the screw that stick to them...
- jonescg
Just ordered 2 of the FTR-J2AK012W relays myself.
- Johny
- Real Name: John Wright
Where are the FTR-J2AK012W available for under $24 ?
- jonescg
That's US dollars. By the time the exchange rate, shipping and GST are added it was more like $41.
I got mine from Mouser.
- Richo
No I got mine for AUD$25.10 inc gst landed.
But as a big time buyer I bought thousands of dollars of parts in one order and I get discounts on top of that.
John Doe off the street has no chance...
They are quite good as they are really 2 seperate relays in one.
So I can use ONE as a mini contactor for both the + and - rail.
- Richo
here go nuts...
https://www.verical.com/pd/fujitsu-rela ... 2w-5716973
- Richo
Oh yes Mouser now adds GST even in USD
- Richo
After a year the EVC80 are still not available.
Waiting .. waiting .. waiting ...
How long can it take to wrap some wire near some metal plates.
