Vac switch--- closed
Locked
Goombi
Real Name: Eugen
Post by Goombi »
I have obtained one Thank you all for your info   Cheers
I noticed this during my eBay travels...
http://cgi.ebay.com.au/VACUUM-DIAPHRAGM ... m153.l1262
Mark T
Real Name: Mark Taylor
Post by Mark T »
I purchased one of these from RS Components.
It seems to work OK.
Mark
Peter C in Canberra
Real Name: Peter Campbell
Post by Peter C in Canberra »
I got a vacuum switch from http://www.baccara.com.au/vaccum-switches.shtml
It cost half of the RS price (that's normal).
That have a good range of adjustable and set at various pressures, normally open or closed, different fittings, etc.
I notice one is adjustable from 12-30"Hg which is pretty much what you asked for. The electrical limit is given as '100 Va Max. voltage 42V'. If they mean 100 volt.amps then 12V x 7amps is OK too.
Peter.
Locked
