I'm a little worried my batteries are pretty shot... I have 4x12V/280Ah AGM in series, bought in December 2016.
This evening the inverter started beeping (at voltage <44V) so I hooked up the generator to charge, charging started at 19:29 with 15% SOC reported, and already 10 minutes later at 19:39 the SOC is reported at 95%. Now I know the original SOC value is everything but accurate, but that huge swing during charging does worry me, during a charge of 17-18A.
The charge current does stay at 17-19A and the voltage constantly rises, now at 20:34 it's reached 57.6V, at 20:54 it's reached 58.4V, and still shows 95% SOC. If I leave it running all night it will probably stay that way for another hour or 2 and then slowly go down in current.
Update: it's now 21:48, drawing 12A, voltage at 57.0V (which is what float is set to), SOC still reports 95%. Theoretically the generator should have put about 2kWh into the battery this evening.
Update 2 at 21:58: i just changed the float voltage to what it should be (55.2v) and the charge current is now 9-10A. So the batteries are still "eating" about 500W.
Code: Select all
Device mode Time AC_volt AC_freq PV_pow app_pow act_pow Bat_vol SOC Chg_cur dch_cur
Line Mode 2018-11-26 21:58:00 - - 0 - - 55.2 95 10.0 0.0 // added manually
Line Mode 2018-11-26 21:48:00 - - 0 - - 57.0 95 12.0 0.0 // added manually
Line Mode 2018-11-26 19:42:13 241.2 49.1 0 241.0 180.0 54.1 95 18.0 0.0
Line Mode 2018-11-26 19:41:43 238.5 48.5 0 238.0 170.0 54.1 95 18.0 0.0
Line Mode 2018-11-26 19:41:13 240.6 48.5 0 168.0 126.0 54.1 95 18.0 0.0
Line Mode 2018-11-26 19:40:43 242.2 48.6 0 193.0 136.0 54.2 95 17.0 0.0
Line Mode 2018-11-26 19:40:14 243.4 48.8 0 194.0 154.0 54.4 95 17.0 0.0
Line Mode 2018-11-26 19:39:44 241.3 49.1 0 217.0 169.0 54.7 95 17.0 0.0
Line Mode 2018-11-26 19:39:13 242.3 49.1 0 121.0 70.0 52.3 95 18.0 0.0
Line Mode 2018-11-26 19:38:42 247.7 49.6 0 123.0 85.0 49.7 75 17.0 0.0
Line Mode 2018-11-26 19:38:12 248.0 49.3 0 173.0 119.0 49.4 72 18.0 0.0
Line Mode 2018-11-26 19:37:42 248.4 49.7 0 197.0 142.0 49.3 71 18.0 0.0
Line Mode 2018-11-26 19:37:13 247.9 49.8 0 198.0 155.0 49.2 70 17.0 0.0
Line Mode 2018-11-26 19:36:43 249.0 49.2 0 199.0 153.0 49.2 70 16.0 0.0
Line Mode 2018-11-26 19:36:13 247.9 49.1 0 198.0 152.0 49.3 71 17.0 0.0
Line Mode 2018-11-26 19:35:43 245.8 49.4 0 197.0 142.0 48.9 67 17.0 0.0
Line Mode 2018-11-26 19:35:14 244.2 48.9 0 268.0 195.0 49.1 69 18.0 0.0
Line Mode 2018-11-26 19:34:41 243.1 49.0 0 268.0 217.0 49.1 69 16.0 0.0
Line Mode 2018-11-26 19:34:13 244.9 48.8 0 267.0 204.0 49.1 69 18.0 0.0
Line Mode 2018-11-26 19:33:42 243.2 49.1 0 267.0 221.0 49.0 68 17.0 0.0
Line Mode 2018-11-26 19:33:13 227.4 46.8 0 770.0 692.0 49.2 70 17.0 0.0
Line Mode 2018-11-26 19:32:43 227.4 46.8 0 737.0 737.0 49.1 69 19.0 0.0
Line Mode 2018-11-26 19:32:13 228.1 47.3 0 752.0 646.0 48.9 67 19.0 0.0
Line Mode 2018-11-26 19:31:43 227.0 47.2 0 681.0 646.0 48.7 65 19.0 0.0
Line Mode 2018-11-26 19:31:12 230.9 47.1 0 777.0 675.0 48.1 59 19.0 0.0
Line Mode 2018-11-26 19:30:43 235.4 48.2 0 783.0 783.0 47.4 52 8.0 0.0
Line Mode 2018-11-26 19:30:10 233.4 49.4 0 755.0 755.0 43.9 17 0.0 0.0
Line Mode 2018-11-26 19:29:44 239.6 49.2 0 718.0 680.0 44.0 18 0.0 0.0
Line Mode 2018-11-26 19:29:11 273.8 50.3 0 216.0 204.0 43.7 15 0.0 0.0
Line Mode 2018-11-26 19:28:44 264.5 50.2 0 158.0 131.0 43.9 17 0.0 0.0
Battery 2018-11-26 19:28:12 0.0 0.0 0 92.0 37.0 43.5 13 0.0 0.0
Battery 2018-11-26 19:27:42 0.0 0.0 0 68.0 44.0 43.6 14 0.0 1.0
Battery 2018-11-26 19:27:10 0.0 0.0 0 92.0 46.0 43.7 15 0.0 1.0
Battery 2018-11-26 19:26:43 0.0 0.0 0 92.0 47.0 43.6 14 0.0 1.0
Battery 2018-11-26 19:26:13 0.0 0.0 0 68.0 37.0 43.6 14 0.0 0.0
