MikeD - E-Max 110S
Other Production EV's including motorbikes, and cars by smaller manufacturers
MikeD
Real Name: Michael Day
MikeD - E-Max 110S
Post by MikeD » Thu, 31 May 2018, 13:37
I recently added a second EV to the vehicle fleet, a Vmoto Emax 110s scooter. They were imported into Australia in 2010 and came with about 100kg of glass mat absorbed lead acid batteries. So were embarrassingly heavy.
Have upgraded the battery pack in mine with 8 Nissan Leaf modules left over from my car www.mr02ev.me giving a total of 65 volts and 3.6kilowatthours. It moves along quite nicely now.
IMG_20170820_131113 (Small).jpg (101.42 KiB) Viewed 1922 times
IMG_20171028_161030 (Small).jpg (138.08 KiB) Viewed 1922 times
IMG_20170820_142929 (Small).jpg (97.74 KiB) Viewed 1922 times
AEVA National & NSW Branch Treasurer
Re: MikeD - E-Max 110S
Post by jonescg » Thu, 31 May 2018, 14:54
Most importantly, how fast does she go!
antday
Real Name: Antony Day
Post by antday » Thu, 31 May 2018, 15:00
Looks great, Mike. Whats the weight difference?
MikeD
Post by MikeD » Thu, 31 May 2018, 17:54
Rought estimate, reduced the weight by 30kg. But at the same time increased the pack voltage from 48v to 65v.
MikeD
Post by MikeD » Fri, 01 Jun 2018, 15:08
I have maxed it out at 70kph!
Post by jonescg » Fri, 01 Jun 2018, 20:53
Interesting. I would have thought that the higher voltage made it spin faster. Mine does 70 on 16s LiFePO4.
Post by antiscab » Sat, 02 Jun 2018, 08:11
That would be a setting in the sevcon controller I would imagine
MikeD
Post by MikeD » Sat, 02 Jun 2018, 17:09
Pretty sure you are right. Have been meaning to find the setup software and tweak the configuration.
