Spongy brakes?
Volt Interest Group
Spongy brakes?
I have found that I have to really push hard to stop
Or start braking earlier
I've gone over the stop line more often than on the imiev
Pumping the brakes at standstill one can feel the sponginess
I tend not to use the brakes a lot due to regen
I guess the best thing to do is drive like a limo driver or chauffeur
Ie smoothly, so that passengers don't spill their drinks
http://www.themotorreport.com.au/54934/ ... ive-review
http://www.autoweek.com/article/2013030 ... /130229849
http://gm-volt.com/forum/archive/index.php/t-7920.html
mushy <added 4 march 2014>
http://www.autonet.ca/en/2011/01/14/201 ... et-volt-en
My only issue with Volt’s otherwise solid driving dynamics is a mushy brake pedal. Most ABS systems don’t let you push the pedal to the floor, this one does.
2011 i-MiEV - k kms 224
marty11
Real Name: Marty
Spongy brakes?
Post by marty11 »
they are different from other cars.
I am more used to the Volt braking now though, and I drive in L all the time and pland touse regen to stop mostly, only push the brake pedal down hard if needed etc.
Am happy with braking here. But I did read the motoring writers comments about the "feel " of the brakes. And perception means a lot! Am sure that gm is aware of it, I believe its mainly in low, under full regen, then applying the brakes, there is a small "gap" or "hesitation" not sure if that is software related whilst hardware is changing things from regen to actual braking.
Holden Volt - June 2013
Solar Charged from 10kw
