e-brake in the Volt
Volt Interest Group
e-brake in the Volt
Post by g4qber » Tue, 29 Oct 2013, 14:53
is this supposed to operate even when the car is moving?
eg. like a normal cable operated emergency / park brake.
this is what occurs in the VW Mk 7 and the nissan leaf.
I've also noticed that the brakes are a bit mushy.
they also deactivate after 10 secs from power down
so make sure that you activate the e-brake before power down
else the car may be resting on its gears in Park
and then have a clunk the next time you start off.
spongy brakes
http://www.themotorreport.com.au/54934/ ... ive-review
http://www.goodgearguide.com.au/article ... rst_drive/
e-brake in the Volt
Post by Johny » Tue, 29 Oct 2013, 14:57
I had a memory that the Leaf handbrake self-energized on power down if you didn't do it yourself.
e-brake in the Volt
Post by g4qber » Fri, 06 Dec 2013, 04:48
E brake works. Just have to hold switch longer, like on a leaf.
Something to try next year at the electrikhana.
Volt doesn't have auto energising.
