Power Source -different plugs,sockets,adapters
Leaf Interest Group
photomac
Real Name: Matthew Clifton
Post by photomac » Wed, 04 Dec 2013, 22:40
So - I have a LEAF, it's portable recharge adapter, E-Station charger, a Jaycar trip-able 10A-15A converter, 15A short extension cord. But, I notice there are other source of sockets at various installs around Perth - like this.
It is called ?
Can I use an adapter - and how - for my LEAF?
Yes,   we can.   Image
Hyundai Kona 64 v1.0 ++Sept 2019 onward. ## 00016+
Mitsubishi PHEV v1.0 ++Apr 2016 to Aug 2019 ##14500 to 72000km
Nissan LEAF v1.0 ++Nov 2013 to Apr 2016 ## 00035 to 36000km
Gabz
Real Name: Gabriel Noronha
Post by Gabz » Wed, 04 Dec 2013, 23:17
it's a 3 phase 415V neutral earth 5 pin.
Contact brian over at the australian leaf owners forum and he'll make you a 3 phase to 15amp cable. you just pick one of the phases and use the earth and neutral.
Post by coulomb » Thu, 05 Dec 2013, 03:02
photomac wrote: It is called ?
Gabz mentioned that it's a 3 phase 415V neutral and earth 5 pin socket. I would add that it's the 32 A variety, with the line and earth pins larger than the central neutral pin (hope I got that right). There is also a 20 A variety that is not compatible in any way.
Post by acmotor » Thu, 05 Dec 2013, 05:54
3 rules.
Get permission.
Get permission.
Get permission.
Have your adapter test and tagged.
I have 20 and 32A versions in regular use. They have 16A RCDs in an inline box to the 15A socket. It should all be at least IP55 if located outdoors.
Know where the switch board is.
Gabz
Post by Gabz » Thu, 05 Dec 2013, 13:39
acmotor wrote: 3 rules.
Get permission.
Get permission.
Get permission.
I assumed it's a picture of one of city of perth parking charge sites http://www.recargo.com/sites/7987 Which means there is a sign next to it saying it's ok. they are all 3 phase i think because the cars used in the EV trial had type2 mennekes 3phase inputs. but yes if no sign make sure you ask.
Post by g4qber » Thu, 05 Dec 2013, 14:41
http://www.ebay.com.au/itm/32amp-Indust ... 27c6ca8388
e-station makes these up via a qualified electrician.
acmotor could you please post a pic of your cable. TIA.
Post by acmotor » Thu, 05 Dec 2013, 17:25
wiclo,
Just a note. The adapter cable should contain a 16A current limiting device. I would question an electrician having connected a 32A plug directly to a 15A socket. I did raise this with Patrick.
Post by g4qber » Thu, 05 Dec 2013, 18:53
The WA EV trial Ford Focus conversions had 3 phase plugs in the vehicles and allowed 32A 3 phase charging.
http://www.evworks.com.au/index.php?product=310
photomac
Post by photomac » Sat, 18 Jan 2014, 00:13
E-Station has efficiently built and delivered a 3-phase, 30A plug to 15A single phase socket ( At least that's what I think it is ) and they have honoured a good discount as I am a AEVA member. I used it successfully in "His Majesty's Theatre" carpark, Perth. Thanks E-Station!!!!!
By the way, I have also received a RFID card for the Leederville charge point. It is different to the ChargePoint RFID in Mt Lawley. The Leederville one is available from the Leederville Council for $20. If you have an E-Station Charger at home I think they will throw the RFID card in. Thanks again E-Station!!!
Yes,   we can.   Image
Post by g4qber » Sun, 13 Apr 2014, 13:51
Cockburn youth centre has massive 63A 500V connector 30kW plug
the yellow sockets are only 10A 240V single phase unlike the city of Perth's 32A 3phase 415V
amazing it was open September 13 2008 hence the use of the yellow industrial switches cos the 2010 WA EV trial was taking place about the same time.
Post by g4qber » Wed, 16 Jul 2014, 15:51
http://cityofperthparking.com.au/sites/ ... 015(1).pdf
City of Perth parking mentions Ev parking bays
2011 i-MiEV - k kms 208
Post by antiscab » Wed, 16 Jul 2014, 22:35
That 63A point is actually good for 44kw as it's 3-phase (63A * 240 * 3 or 63A * 415V * sqrt(3))
just need a big enough charger now :D
Post by g4qber » Fri, 18 Jul 2014, 08:20
just noticed that it says No fee for EVs does it mean that it is free to park EVs in city of perth car parks?
I need to do more research.
Post by g4qber » Wed, 08 Oct 2014, 15:16
found out from city of perth parking that
still have to pay for parking, but electricity is free for now
Post by g4qber » Fri, 24 Oct 2014, 14:54
Cockburn Gateway Chargepoint Australia
Dual J1772 is alive! I'm gonna check it out tonight
the youth centre also allows 10A charging on their stage
the 63A 3phase box has been removed
Post by jonescg » Fri, 24 Oct 2014, 15:01
Mark and/or Ant were there this morning talking with the media about the new charge point. Hopefully 7 kW a side. Too bad no production EV can make use of this power. Maybe the 2015 Leaf will come with a 7 kW charger?
Post by g4qber » Fri, 24 Oct 2014, 15:52
BMW i3 may make use of this capacity.
2nd gen leaf charges at 32A.
but Nissan Aus will probably skip this due to overstocking of gen 1 LEAFs.
