Curtis 1221C
KDRYAN
Real Name: Kim Ryan
Curtis 1221C
Post by KDRYAN »
Hi All
I am fitting a Curtis 1221C controller to my Proton Satria conversion, (120volt) reading the controller manual it states that the plug braking feature should not be used for on road vehcles. Is it the normal thing to not connect a cable fron the A2 on the controller to the motor. Has anyone come accross this with conversions in the past?
Regards
Kim
Curtis 1221C
Hi Kim,
the negative tab on the controller should be common with both the batteries and the motor.
there should also be separate positive tabs to both the motor and the batteries.
Im not sure what these are labeled as, but i would be surprised if the 1221C has a seperate tab to go to the motor for plug braking.
zeva
Real Name: Ian Hooper
MSN: sigmunky@hotmail.com
Curtis 1221C
Post by zeva »
Whoah there Matt.. your Zilla is different to the Curtis controllers.. Curtis (in fact most DC controllers) have B+ and M+ common, with B- and M- separate:
http://www.zeva.com.au/tech.php?section=circuits
(Zilla seem to be the odd one out - maybe using the IGBTs on the high side internally for some reason?)
But in response to your question Kim, yes you can safely ignore the A2 (plug braking) terminal on your 1221, it doesn't serve a useful purpose for us and is reputed to be rather "under-rated" for the big motors we use in road-going EVs!
Ian Hooper
Taffy
Real Name: Taffy Flynn
Curtis 1221C
Post by Taffy »
We use it on the e-racing car and when you place the terminal side towards you we have the bottom right unconnected.
That is the A2 and the car runs fine.
