Replacement bearings for AC Motor
cts_casemod
Real Name: Carlos
Post by cts_casemod » Sun, 28 Oct 2012, 11:27
Hi all,
I am looking into a bit of information about bearings to my motor.
I am doing an AC Conversion on a Polo, and Ive noticed my motor is very load over 2000RPM, due to worn bearings.
Previously this motor had metal shielded bearings, which I believe are not the best for a car conversion as the motor will be in contact water and dirt from the roads on the winter.
I could use rubber seals, but I have been advised this are not adequate for high speed operation.
I am trying to know what does this high speed operation refers to as i have no figures on RPM's.
My Motor will go up to 2900RPM and will will usually work on the 1500-2000
Any advice on this?
Post by acmotor » Mon, 29 Oct 2012, 05:53
Bearing manufacturer's data tables will give you all the information on seal types and working RPM.
SKF for instance
Image http://www.skf.com/portal/skf/home/prod ... link=1_1_3 click on table 1
I would use double full contact rubber seal bearings. (for max waterproofing and grease retention)
At a guess the OD of the (most likely) single row, deep groove ball bearings that you use is about 80mm ?
http://www.skf.com/skf/productcatalogue ... tartnum=17 say 6307-2RS1 (double rubber seal)
These have a limiting speed of 6000RPM and would suit your application.
What is the part number of your existing bearings ? DE and NDE
There are other options of temperature range, grease type and noise level. The standard types would be quite suitable for EV motor.
edit: spelling !
cts_casemod
Real Name: Carlos
Post by cts_casemod » Mon, 29 Oct 2012, 06:32
Thanks acmotor.
My bearings are 6206Z for the Fan side and 6208Z for the output shaft side.
The Z stands for metal shield, I am now replacing them with a SNR 6208EE ruber one and I am yet to buy the Fan side one.
This ones are quite expensive so they should have some quality. I am particulary concerned as I will keep the clutch and its heavy!! Any advice on this?
Checked the manufacturer datasheet they state 5200RPM for ruber and 15000RPM for metalic shied. I have no idea why a 4 Pole motor would come with metalic shild then lol ;)
Post by acmotor » Mon, 29 Oct 2012, 06:53
You're on to it.
Have the cut down flywheel, pressure plate and clutch plate spring assembly balanced on the motor shaft. Either by a dynamic balancing shop or a least on your own bench. I assume the emotor rotor was balanced at manufacture.
cts_casemod
Real Name: Carlos
Post by cts_casemod » Mon, 29 Oct 2012, 08:11
What do you mean cut down? Reduce the flywheel weight/mass?
How do you balance the motor yourself on the bench?
