Is this motor suitable for an ev?
gregted
Real Name: Greg Tedford
Post by gregted » Fri, 03 Aug 2012, 02:44
Just realised I had a big electric motor sitting in the garage that may be suitable for my 1981 Ford Courier ev project.
A while ago I was given a 7.5 kva dunlite genset and it has sat in the corner of my shed since.
The motor is huge. 320mm long, 270 diameter and bloody heavy.
Plate on side..
Don't know how this will work being a generator and the max revs may be too low... Any ideas
The future isn't what it used to be.
Post by Johny » Sat, 04 Aug 2012, 02:36
It's a single phase generator - unfortunately not much use. I can't see how you would control it's speed.
Post by BigMouse » Sat, 04 Aug 2012, 03:19
Maybe not as a motor, but perhaps as a range-extender!
gregted
Post by gregted » Sat, 04 Aug 2012, 14:54
It looks more and more like my old 81 courier ute might be the donor roller so are you saying that this on the back could be a range extender? Sort of like a poor mans plug in hybrid!
Post by BigMouse » Tue, 07 Aug 2012, 04:26
Yeah. 7.5kVA would do a fair bit, though probably not enough to keep going indefinitely.
