Prius motor voltage
Martin
Prius motor voltage
Post by Martin »
Looking at the last three prius battery/motor voltage sets, the battery has crept down from 288v (ish) to 240v (ish) to just over 200volts. Meanwhile, the motor in the third (200ish volt) version is rated to 500 volts.
Considering for a given power rating, voltage is the way to go over amps, how have the toyota engineers chosen to bump up the battery voltage like that - efficiently?
250 km's or bust
Tritium_James
Real Name: James Kennedy
Prius motor voltage
Post by Tritium_James »
There's a ~50kW bidirectional boost converter built into the motor controller power electronics box.
Martin
Prius motor voltage
Post by Martin »
Ok, is there more to it than using electronics to add to the +200 supply already available by using a reversed -200v from the same battery pack? (I realise that still only comes to 400ish volts...)
(And is this method used in other available controllers?)
250 km's or bust
Prius motor voltage
Martin wrote: Ok, is there more to it ...
Yes, it's a standard half-bridge converter (buck/boost). Two switches, controlled appropriately. By varying the PWM duty cycle, you get buck, boost, or pass through, bidirectionally.
As far as I know, this is unique, or very rare. I think they went to some trouble to ensure that it was still efficient when not up-converting (e.g. motors need < 200 V).
Martin
Prius motor voltage
Post by Martin »
So it is worthwhile going to all this trouble to supply a motor with a higher voltage than the battery pack can provide on its own.
Any chance of a reference to the buck/boost process for a better understanding? (if it's not available commercially anywhere)
250 km's or bust
Prius motor voltage
Martin wrote: So it is worthwhile going to all this trouble to supply a motor with a higher voltage than the battery pack can provide on its own.
I would say no, the increased cost and weight of a buck boost circuit before the main controller power stage (this will be the size of your controller and your motor windings) in most cases outweighs the increased sized and cost of the BMS to deal with a larger number of smaller cells.
the wikipedia write up is good for getting a basic understanding of how a buck converter and boost converter works.
buck converter write up on wikipedia
boost converter wrtie up on wikipedia
