90AHr LiFePo cells plus charger and more for sale
lachlanmac
Real Name: Lachlan Maclean
Post by lachlanmac » Fri, 25 Aug 2017, 18:52
When I dismantled my EcoRolla and sold the motor and controller, I kept the 45 x 90AHr cells (thundersky and winston) plus all the extra stuff listed below, because I was going to add EV grunt to a toyota prius C. But now Im not, so I want to sell the lot to someone who needs to save some money on their own conversion.
45 x 90AHr cells. plus two more which do hold charge. Nominal 144volts
45 EV Works BMS modules plus the BMS controller.
TC Charger.
laminated copper and also braided copper battery connectors
2 x 400 amp fuses.
1 x contactor
Lengths of 50mm orange cable and crimp connectors
Current and voltmeters (digital) and a ammeter shunt.
The cells where all charging and holding charge etc. when I last drove the EcoRolla.
$3000 for the lot. I would prefer not to separate.
Re: 90AHr LiFePo cells plus charger and more for sale
Post by jonescg » Fri, 25 Aug 2017, 20:43
The battery alone would make a great PV storage battery. Shipping to Perth is a bit silly though... ;)
Should move in no time Lachlan.
nuggetgalore
Real Name: Andreas Tobler
Post by nuggetgalore » Thu, 07 Sep 2017, 20:22
TC Charger.
2 x 400 amp fuses.
1 x contactor
Hi, sent you a PM but did not hear back.
Maybe it failed to deliver
Jodie
Real Name: Jodie
Post by Jodie » Mon, 11 Sep 2017, 10:05
Same here.
Please let me know if the goods are still available.
I'm local.
0425850770
