8" DC motor
8" DC motor
Post by offgridQLD »
I am listing this motor for sale for another person.
Simple good quality brushed Dc motor from Advanced DC Motors and drives USA. A great motor in a small car to replace a 4cyl ICE.
72-120 Volts Cont: 178A Peak: 300A (5min) Cont: 22HP Peak: 83HP Weight: 107 lb Shaft: Double Size: 8"
Operating range 72 to 120V
Weight: 48.5kg
Diameter: 20cm (8.0") Length: 37cm (14.7")
At 72 volts
Continuous rating: 12.1 kw (16.0 hp)
Peak output: 31.5 kw (42.0 hp)
At 96 volts
Continuous rating: 14.4 kw (19.0 hp)
Peak output: 51.0 kw (68.0 hp)
At 120 volts
Continuous rating: 16.3 kw (21.7 hp)
Peak output: 62.0 kw (83.0 hp)
Motor was purchased brand new a few years ago for a EV project but was never used due to owner buying a OEM EV. All reasonable offers will be considered. It's Located in Brisbane.
There is a motor Controller also available if needed. I can get details on it if there is interest.
For more info Contact the seller - Rob at rob@greenfieldpower.com.au
8" DC motor
Motor and controller have been sold
