Possibe ICE Donor Vehicle...?
lithbattboss
Post by lithbattboss »
I came across this possible ICE donor vehicle with a blown motor and thought it might make a good EV conversion.
But questions remain.......
What motor? AC or DC? Perhaps a Zilla controller?
Is the chassis strong enough for lead acid batteries (body looks good...no sign of rust) or should I just spare the expense and go with lithiums?
Any suggestions? Image
Where power matters.
www.lifetechlithium.com
Considering the frame being somewhat on the lighter side I would definately go the lithiums (might even be able to score you a good deal of some LifeBatts)
Motor wise I would be inclined towards something mid mounted for better weight distribution. If you budget stretches that far maybe a AWD conversion??? Image
Lumbar support looks harsh.
Nevilleh
Real Name: Neville Harlick
Post by Nevilleh »
Definitely a problem meeting ADRs.
Nevilleh wrote: Definitely a problem meeting ADRs.
Nah just remove one of the front wheels and register it as a trike. Don't need to worry about crumple zones then.
Digger11
Real Name: Digger Jones
Post by Digger11 »
Go the Zilla 2k, you always need more power.
lithbattboss
Digger11 wrote: Go the Zilla 2k, you always need more power.
The Zilla 2k sounds like a good idea with A123 cells.
The suggestion by EV2Go of a 4 wheel drive conversion is a good one since I have seen similar model vehicles parked in the most rugged places such as bush land, creek beds and the like. So these vehicles definitely sound like a good candidate for 4 wheel drive conversion.
Thanks for the suggestion EV2Go! Image
The express lane at Coles takes on a whole new meaning ! Image
Is this a comment on the design philosophy of Honda ? Image
OK, front wheels as castors and hub motors on the rear with steering via torque distribution to hub motors.
Go DC if you really have to, just as long as the DC ends at the battery terminals. Image
Lithium ? Just as long as there is room for the shopping you can power it anyway you like.
Does that mean we get lithium at supermarket prices ? Image
Put SLA on the bottom frame to keep the centre of gravity low to improve handing.
I'm sure by the time the batteries are out of charge you'll be begging to get out anyway. Image
marcopolo
Post by marcopolo »
lithbattboss wrote: I came across this possible ICE donor vehicle with a blown motor and thought it might make a good EV conversion.
Ah, Ha, see the fully realised and perfected production model on the Bernard the Bear, episode Bernard and the cart!
