Page 1 of 24
Obsolete Thread
Posted: Fri, 08 Jan 2010, 23:52
by EV2Go
EV2Go's - Lithium Powered Trike
Posted: Fri, 08 Jan 2010, 23:56
by EV2Go
Posted: Sat, 09 Jan 2010, 01:57
by acmotor
Well that takes the cake ! Image I've never seen an EV project start with the crown and pinion gear set for the diff !!!
This is going to be a must watch project ! Go for it EV2Go ! Image
Posted: Sat, 09 Jan 2010, 02:23
by EV2Go
Posted: Sat, 09 Jan 2010, 17:34
by a4x4kiwi
hmm 6.5:1 diffs available. Good for a rewound AC :)
Posted: Sat, 09 Jan 2010, 23:48
by EV2Go
Posted: Sun, 10 Jan 2010, 03:21
by Squiggles
a4x4kiwi wrote: hmm 6.5:1 diffs available. Good for a rewound AC :)
Available from where?
Posted: Sun, 10 Jan 2010, 04:15
by EV2Go
Posted: Sun, 10 Jan 2010, 15:14
by Carv'n Marv'n
...any chance of getting this beastie to lean?? like the Honda Gyro or Monkey Trike??
Posted: Mon, 11 Jan 2010, 22:59
by EV2Go
Posted: Tue, 12 Jan 2010, 00:59
by Carv'n Marv'n
look at the Honda Gyro more closely - also the Carver - the motor and diff can stay fixed - with the front end tilting. Potentially having all weight over the fixed section, including batteries. The tilting section can be made quite light.
It can be achieved quite simply... bit of lateral thinking required.
Posted: Tue, 12 Jan 2010, 20:40
by EV2Go
Posted: Tue, 12 Jan 2010, 20:47
by woody
Yes, I can see the tilting trike tilting you right (or left) into the pavement when you hit the throttle, unless the motor doesn't tilt...
Posted: Tue, 12 Jan 2010, 20:51
by EV2Go
Posted: Wed, 13 Jan 2010, 16:49
by Carv'n Marv'n
...say at 100MPH, would you want to attempt to take a corner with a rigid trike??
Body won't be doing it's own thing, it would not want to drop you on the pavement or do crazy unexpected things. When you give it power it would want to bring you upright again - same as a two wheeled motorbike.
...in the sketch - the pivot line is just above the footboards - hinged at two points. The footboards are part of the rear section, and remain level at all times. The front section could be spring loaded to help it return upright (gently) or hold it upright in a parked position.
Posted: Wed, 13 Jan 2010, 21:24
by EV2Go
Posted: Thu, 21 Jan 2010, 00:13
by AussieJester
EV2Go wrote:
You know maybe that's not such a bad idea... since I am pretty much stuck with a bike front end (mostly tyre) I could get better millage out of the front tyre if it leaned.
The rake on the forks takes care of the wear on the side of the tire, my front tire of my trike wears pretty much like a standard two wheel bike. Many ICE trikes are not built leaning, they corner well tilting is nice but i wouldn't be too focused on it, its complicated to setup...
Best of luck anywayz...
KiM
p.s for a diff you might want too look up Fiora machinery on the net, they are local to me and build fantastic trikes, they are available in kits for also i believe...
Posted: Fri, 22 Jan 2010, 06:16
by EV2Go
Posted: Thu, 28 Jan 2010, 21:27
by EV2Go
Posted: Thu, 28 Jan 2010, 21:45
by AussieJester
Looks alot like a jag rear end
Additional pics
http://www.rodandcustommagazine.com/tec ... to_02.html
Hot Rod crowd have been using them for many years behind big HP V8s
if they stand up to that im sure you lil lecky motor wont worry it :-)
KiM
Posted: Thu, 28 Jan 2010, 22:21
by Squiggles
My friends GT40 replica uses a Porsche transaxle, anything wrong with the good old VW unit?
Posted: Thu, 28 Jan 2010, 23:00
by AussieJester
^^^prolly the fact his 1000 dollar Nascar 9in gear set wont fit in a VW...soz didn't realise that when i posted the Jag rear end either...
KiM
Posted: Fri, 29 Jan 2010, 21:58
by EV2Go
Posted: Fri, 29 Jan 2010, 22:15
by EV2Go
Posted: Sat, 30 Jan 2010, 01:31
by Electrocycle
you don't really need IRS on a trike.
I probably still have an S13 rear suspension setup if you wanted to try one, but I think a normal solid diff would be the way to go.
