Obsolete Thread
EV2Go
EV2Go's - Lithium Powered Trike
Post by EV2Go » Sun, 31 Jan 2016, 18:29
EV2Go
Post by EV2Go » Sun, 31 Jan 2016, 18:32
Post by Adverse Effects » Sun, 31 Jan 2016, 22:23
EV2Go wrote:I would have to do something insane to break it.
hmmmmm
and here i was beveling you are building it to do just that
i must be slipping in my old age
EV2Go
Post by EV2Go » Mon, 01 Feb 2016, 00:06
Post by Adverse Effects » Mon, 01 Feb 2016, 00:35
Image Image Image Image Image Image Image Image Image Image Image
EV2Go
Post by EV2Go » Sat, 06 Feb 2016, 01:58
Post by Adverse Effects » Sat, 06 Feb 2016, 03:40
oil return holes?
looks beefy
EV2Go
Post by EV2Go » Sat, 06 Feb 2016, 18:14
Post by T1 Terry » Sat, 06 Feb 2016, 20:29
So this piece replaces the front brg support and oil seal retainer and incorporates the motor mounting flange, is that correct? What coupling are you planning to use between the motor shaft and the diff pinion?
EV2Go
Post by EV2Go » Sat, 06 Feb 2016, 21:44
Post by Adverse Effects » Sat, 06 Feb 2016, 22:57
ahhhh ok T1 Terry got to it before me
Post by T1 Terry » Sat, 06 Feb 2016, 23:01
Nylon coupling to soften the shock loading? I've been looking at different ideas for the coupling, I bought a cushion coupling (rubber blocks between the 2 halves) from BigMouse when he was having his garage sale but I've been thinking along the lines of a V toothed coupling with spring loading so a sudden shock load would not be unloaded on the pinion/ringear tooth facings. Using a guide shaft type of fitting where one half slides inside the other half would allow preload to be measured before assembly and the act of pulling the motor up snug to the housing would apply the required preload and an easy to fit coupling. From past experience soft mount couplings are not easy to assemble when you can't see what is happening as they engage.
EV2Go
Post by EV2Go » Sun, 07 Feb 2016, 01:58
EV2Go
Post by EV2Go » Thu, 18 Feb 2016, 05:27
Post by Adverse Effects » Thu, 18 Feb 2016, 13:17
the motor clamps / bolts / what ever to the big flange?
if so do you even want oil to get in to that area?
EV2Go
Post by EV2Go » Thu, 18 Feb 2016, 17:56
Post by Adverse Effects » Fri, 26 Feb 2016, 00:00
here is the addon i was talking to you about
SketchyPhysics
SketchyPhysicsWiki
[tube]https://www.youtube.com/watch?v=qLvXvzPvfWI[/tube]
EV2Go
Post by EV2Go » Fri, 26 Feb 2016, 02:03
Post by Adverse Effects » Sun, 28 Feb 2016, 02:16
how you liking SketchyPhysics
EV2Go
Post by EV2Go » Sun, 28 Feb 2016, 05:02
Post by Adverse Effects » Sun, 28 Feb 2016, 05:12
good job and yes its a head scratcher at times lol
EV2Go
Post by EV2Go » Tue, 08 Mar 2016, 01:01
Post by Adverse Effects » Tue, 08 Mar 2016, 13:51
LOL that is a sexy hunk of iron
EV2Go
Post by EV2Go » Fri, 11 Mar 2016, 16:43
EV2Go
Post by EV2Go » Sun, 07 May 2017, 19:01
Locked
