Automatic EV
MikeG
Real Name: Mike Glew
MSN: michaelglew@hotmail.com
Automatic EV
Post by MikeG »
Has anyone retained the automatic gearbox in an EV conversion? What needs to be done? Does the AT need to be re-tuned to suit the new powerplant (different torque converter and change points)?
MikeG
Automatic EV
Post by woody »
I haven't heard of one, the 2nd hand advice I have is that you need to keep the electric motor turning to keep the oil pressure in the gearbox up. Also that torque converters are not very efficient.
Automatic EV
Post by acmotor »
Rob M has done one, you could PM him or visit his web site www.evwa.com.au www.evwa.com.au
(if he doesn't pick up this post that is)
Torque converter was removed. He ran (is still running ?) it in the Mustang.
Martin
Automatic EV
Post by Martin »
The auto I'm running behaves itself without a motor constantly running for the auto fluid.
The only thing is a slight delay when swapping from Drive to Reverse    (& visa versa), but even that is only a 'hesitation'.
Automatic EV
Post by woody »
Hi Martin,
What car/transmission is that?
The reason I ask is that many are common, e.g. Borg Warner 35 was the automatic in most cars in Australia in the 60s, 70s + 80s.
Most of the rest were THM-350s :-)
cheers,
Woody
Martin
Automatic EV
Post by Martin »
Just a simple suzuki auto
(Mighty boy seemed most suited for conversion - just happened to get an auto)
250 km's or bust
