AEVA Homepage
Forum Home Forum Home > General > General EV Discussion
  Active Topics Active Topics
  FAQ FAQ  Forum Search   Register Register  Login Login
Good Donor car??
Author
Message
  Topic Search Topic Search  Topic Options Topic Options
EV1day View Drop Down
Online Status: Offline
  Quote EV1day Quote  Post ReplyReply Direct Link To This Post Topic: Good Donor car??
    Posted: 17 October 2008 at 11:01am
Any ideas???
Thanks,
Scott
Back to Top
evkartalex View Drop Down
  Quote evkartalex Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2008 at 12:28pm
daihatsus are popular
G11 chassis is easy to convert, as much the same as a G100 chassis
other people have used G100 chassis
i plan to use either a L80 mira or G11 charade myself
regards
alex
JR FORKLIFTS - All your Electric forklift needs!
Back to Top
Richo View Drop Down
AEVA Member
AEVA Member
Avatar
  Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2008 at 4:42pm
The one that is cheap with a (near)dead motor.
The lighter and more aerodynamic it is will mean less(small) requirements on battery/motor for the same performance.
Celica Mustang
Battery + controller + ACIM - ICE = eV
Back to Top
antiscab View Drop Down
Admin Group
Admin Group
Forum Admin
  Quote antiscab Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2008 at 12:14am
other choices:
honda insight
toyota mr2
toyota prius (has heavy drivetrain that can be removed)
fiat fsm nikki 126
mazda mx5
suzuki mightboy
any ute
vehicles with heavy drivetrains (such as hybrids, or iron block V8s)
http://www.evalbum.com/1499
http://www.evalbum.com/1809
Back to Top
AEVA Member
AEVA Member
Avatar
  Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2008 at 4:00pm
There is a mini 850 and a niki in this weeks Quokka.
Both around $1000.
datto 1200 ute on e-bay in WA but is too rusty unless your very keen.
Old style Fairlane have heaps of room for batteries if you want a long range cruizer.
They're all good - any eV is better than a petrol burner.
Back to Top
AEVA Member
AEVA Member
Avatar
  Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2008 at 11:13pm
I hear the BMW's are good to convert
Back to Top
AEVA Member
AEVA Member
Avatar
  Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2008 at 1:18pm
How about a 86 Toyota Corolla
Lots of spares and licenced at $50 you can't go wrong!
Back to Top
woody View Drop Down
AEVA Member
AEVA Member
Avatar
  Quote woody Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2008 at 6:34pm
Something that you'll be happy dribing for the next 5-10 years
I like older cars - if you pull out the ICE, everything else still works - instruments, steering, brakes. They also tend to be lighter. A '62 Valiant weights less than a new convertible mini.
New cars have safety and airbags and stuff, if you like that :-)
cheers,
Woody
Planned EV: '63 Cortina using Industrial AC and LiFePO4 Battery Pack
Back to Top
AEVA Member
AEVA Member
Avatar
  Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2008 at 2:13pm
Back to Top
AEVA Member
AEVA Member
Avatar
  Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2008 at 2:24pm
'84 ALFA ROMEO 33 GCL
Motor seized so going cheap!
Buy it - you know you want to
$750 is a steal
Back to Top
Goombi View Drop Down
Avatar
  Quote Goombi Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2008 at 3:50pm
I have Holden BARINA EASY TO FIT ALL AND PLENTY OF ROOM FOR 96 VOLT AGM BATTERY SYSTEM and 9.2 inch 8.5 Kw motor. Barina is ideal for conversion I have almost finished conversion -tomorrow will be the test.. apart from gauges and small details like connecting demister and battery box ventilation fan its all done and i did buy woolen seat covers and a AEVA shirt and still under $ 6000
Visit my web site : www.goombi.4t.com
www.evbrumby.mysite.com
Back to Top
AEVA Member
AEVA Member
Avatar
  Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2008 at 4:08pm
Since this link has been moved from the PERTH area most of the cars discussed above are from PERTH so please ignore them if you are in other states.
Back to Top
  Quote EV1day Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2008 at 9:05am
Ok. Looking at a 2001 Daewoo Matiz. Small, fairly aerodynamic and 4 seats. Anyone done a conversion with this car?
Scott
Back to Top
Avatar
  Quote Goombi Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2008 at 10:25am
72 volt only and batteries where the back seat is making it a 2 seater Matis is very light It is the smallest vehicle that was on the market --since doscontinued. If 72 volt will suit you then go for it first measure the gearbox and motor lenght and see if you can fit 300mm long el motor..without demolishing the main frame Try- Charade, barina, Echo
Fiesta, cars that hold around 1300cc motors should be suitable most Cheers
Back to Top
sparau View Drop Down
  Quote sparau Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2008 at 10:35am
i bought a cheap peugeot 205gti with the idea of converting when i can magically get hold of 22K...
a bit heavier than some of the other options but probably a bit safer when the tool crashes their 4wd into you.
Back to Top
Avatar
  Quote Goombi Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2008 at 10:40am
Sparau, please forget about 4x4 vehicles running into you. By the time you finish making it there won't be any 4x4
Back to Top
Thalass View Drop Down
Avatar
Online Status: Online
  Quote Thalass Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2008 at 11:28pm
No 4WD? Not if I can help it! heh. Most of the guys I know will go to their grave before giving up 4x4.
Back to Top
bga View Drop Down
Avatar
  Quote bga Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2008 at 6:36pm
Don't forget about pesky car electronics. Usually not an issue for older cars, but newer models may be problematic. The body computer may refuse to cooperate after the engine is terminated, making the car kind of useless.
I have thought that a recent, lead filled, commodore would be a good target from the point of view of having a neat graphics display in the middle of the dashboard, but subduing the various computers is likely to be a ugly affair that's harder than designing them in the first place was. After all that, the conformodore is seriously heavy at 1650Kg, making the drive and batteries an epic.
Some research is needed, because it won't be long before computers and electronic stuff become the norm in donor vehicles.
BGA
Edited by bga - 01 December 2008 at 6:38pm
Back to Top
fuzzy-hair-man View Drop Down
Avatar
  Quote fuzzy-hair-man Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 3:33pm
If you were going for a modern car I reckon a Toyota Paseo would make a pretty good EV, it got good aero (0.32 coefficient drag and 1.7m2 frontal area) and it's reasonably light at 939kg.
It does have power steering and disks so therefore would need a vacumn pump and power steering pump, but hey you can't have everything. GVM is 1349kg so there's a little bit to play with for batteries. However it's an alloy block and head so you probably won't loose as much weight as if it were cast iron...
And IMO Toyota generally build good solid cars.
A quick look found them for as low as $3000
Back to Top
Avatar
  Quote Goombi Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 3:39pm
GVM pretty heavy anything smaller?
Back to Top
AEVA Member
AEVA Member
Avatar
  Quote Richo Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 3:53pm
Ding Bob Trike certified frame.
Light and ready to put emotor and batteries in.
$4500.
Back to Top
Avatar
  Quote fuzzy-hair-man Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 4:20pm
GVM is the load / maximum weight capacity, the curb weight is 939kg.
I hadn't seen many modern cars make it under the 1000kgs for curb weight but maybe I'm looking in the wrong places.
What did your Barina start out weighting? Ah found it 780ish kg (94) is good! I thought the Barina must have been somewhere near the 1000kg to start so I was wondering how you kept the weight down.
I'm an old car and mini fan myself so if I did an electric car I think I'd do a mini.
A Datsun 1200 Coupe would be a good proposition too everything Nissan/Datsun seems to swap over easily so the suspension from a 1200 ute would probably swap straight over if it isn't the same already, but then again I never looked.
Edited by fuzzy-hair-man - 02 December 2008 at 4:21pm
Back to Top
Avatar
  Quote Goombi Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 4:32pm
Mini OK.. I like it.. its all very nice to go with older cars but you will live in a EV for years to come so barina's- mazda 121- Charade- are relatively modern cars and if no rust will see you out
Back to Top
Avatar
  Quote fuzzy-hair-man Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 5:35pm
A mini is the car I'd drive out of choice at least until I have to go long distance or fit more stuff in, so I could live with a mini quite easily (well I sort of do already).
A lot of the things in modern cars rather annoy me just extra kruft to get you to buy the latest model which is really no better than the last one IMO . (others probably differ)
I sometimes think this might be one of the reasons why car manufacturers don't much want to go electric, once you make a car that is 80% or whatever efficient and has a motor which will last almost forever (I read a Semiens had a warranty for 15 years) then what's the point of buying a new car? In practical terms it can't really be that much better than the old one can it? I'd keep the old one and run it till the wheels fall off and save my money for more worthwhile things.
My rather biased opinion is more cars should be like the mini bare bones, minimalist, great handling and practical. In fact for a conversion a mini could be relatively easy, no brake booster, no air conditioner, no power steering, no heater, no radio (although I'd hook up something to plug my MP3 into so I can have some tunes) , a heavy cast iron block and head and a fair lump of a gearbox, and a starting weight of ~600kg.
Issues would be awful aero drag (0.53) and where to stick enough batteries. It's a commuter though so it should be kept around 60km/hr most of the time anyway... and maybe I'll get rid of the back seats.
I think I've liked minis since I saw a family of 4 somehow disappear inside one.
Back to Top
Avatar
  Quote Goombi Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2008 at 7:04pm
--MINImalist and bare bone cenversion I am with you all the way but be very carefull you will be critisised for creating plebayan society.
There are people here that love their EX habit from comforts of ICE...
Back to Top
Forum Jump Forum Home Forum Permissions View Drop Down
Bulletin Board Software by Web Wiz Forums® version 9.07
Copyright ©2001-2008 Web Wiz
This page was generated in 0.109 seconds.
