Li cell charge tests |
| Author | |
Tritium_James
AEVA Member
AEVA Corporate Member Joined: 04 March 2009 Online Status: Offline Posts: 520 |
Quote Reply
Topic: Li cell charge testsPosted: 23 July 2009 at 12:06pm |
Here's another data point for everyone...
I've just done a test on a Thundersky LFP 90Ah cell to work out how much potential capacity you lose by not charging to the full datasheet max voltage. The test procedure was to do a constant current -> constant voltage charge until the current dropped away to 0. This is then regarded as 'fully charged' at that voltage. I then stepped the voltage up by 100mV, and waited for the current to drop to 0 again. Voltage and current were logged at 0.1 second intervals. The cell was at 3.36V before beginning the test. It took 2.78Ah to bring it to 'fully charged' at 3.75V, my first threshold point. The Ah required for each step are: Ah | Voltage step -------+------------------------ 0.31 | 3.75 -> 3.85 0.32 | 3.85 -> 3.95 0.25 | 3.95 -> 4.05 0.23 | 4.05 -> 4.15 0.24 | 4.15 -> 4.25 Assuming a nominal 90Ah capacity, the percentage capacity you lose by stopping at a lower voltage than maximum is: Lose % | Max charge voltage -------+------------------------ 1.51 | 3.75 1.16 | 3.85 0.80 | 3.95 0.52 | 4.05 0.27 | 4.15 0.00 | 4.25 A graph of the test:
Left-hand axis and orange data in Amps, Right-hand axis and blue data in Volts. Time in 1/10ths of a second. The current spike at T=44088 is where I accidentally changed from 4.05 to 4.5 instead of 4.15, for just under a second. This current is included in the total. |
Nevilleh
Joined: 15 January 2009 Location: Tauranga NZ Online Status: Offline Posts: 470 |
Quote Reply
Posted: 23 July 2009 at 12:38pm |
Yes, that ties in with my much more rudimentary test on a 40 AH cell which indicated a loss of about 2.5% when charged to 3.6v as against 4.2v.
I wonder whether there is a significant increase in life if charged to the lower level? |
AEVA Member
Joined: 23 June 2008 Location: Melbourne Online Status: Offline Posts: 1665 |
Quote Reply
Posted: 23 July 2009 at 12:48pm |
Good test TJ. Very helpful. 2.5 to 3.75V per call gives me 500 to 750 VDC on 200 cells. I had been hoping not to go too far above 750 VDC for various reasons.
Nevilleh. Gut feel is that the difference in life is probably similar to the difference in realisable capacity - 1.5%. Not measurable IMO. However, if there is no temperature compensation during charging (or regen.), keeping the voltage lower may result in longer life. |
Joined: 22 January 2009 Location: Brisbane Online Status: Offline Posts: 1460 |
Quote Reply
Posted: 23 July 2009 at 1:55pm |
Well done, TJ. But I note that it's not certain that putting in 0.31 Ah means you get an extra 0.31 Ah from the next cycle... or even 0.2 Ah. I suspect a lot of it goes into heat.
But since the basic conclusion is "it matters bugger all", and remembering that 5/8 of bugger all is still bugger all, I guess the result stands. |
Nevilleh
Quote Reply
Posted: 24 July 2009 at 10:17am |
I was unable to download the charge/discharge curves for the SE40 from SE's web site, so I asked them to send me a copy. Here they are:
From the discharge curves you can see that the gap between the 4A curve and the 40A curve gets larger as the SOC declines, so the cell internal resistance is getting higher. I make it about 2.78 mR at the 5AH point and pretty well double that at the 40 AH point. |
Quote Reply
Posted: 24 July 2009 at 11:05am |
Interesting that they have changed their specs:
http://www.thunder-sky.com/pdf/TS-LFP40.pdf They are now claiming 5000 cycles at 70 % DOD, 20C impulse discharge, and their discharge curves now include 5C (and down to 2.1 V as well). They still state the minimum operating discharge level is 2.5 V. |
Tritium_James
AEVA Member
Quote Reply
Posted: 24 July 2009 at 1:22pm |
I've run the test on a 2nd cell, and improved the test logging with a more accurate timebase too, just to make sure there wasn't any errors in the test. The results agree reasonably closely. Assuming a 90Ah cell again:
Lose % | Max charge voltage -------+------------------------ 1.84 | 3.75 1.52 | 3.85 1.11 | 3.95 0.78 | 4.05 0.43 | 4.15 0.00 | 4.25 |
AEVA Member
Quote Reply
Posted: 24 July 2009 at 1:29pm |
Nice one TJ.
Just because it takes no effort at all to ask . It would be interesting (but probably not helpful) to extend this down to about the Lose 5% mark.
That is - what voltage are you down to before the cell shows as 95% charged. I guess the amount of time to do this may be a restricting factor. |
Tritium_James
AEVA Member
Quote Reply
Posted: 24 July 2009 at 1:48pm |
Looking at the shape of the discharge curve, I think you'll start losing significant capacity fairly soon if the charge voltage goes any lower.
I'll need to discharge these cells again before I can run more tests. |
AEVA Member
Joined: 25 April 2007 Location: Perth,Australia Online Status: Offline Posts: 2472 |
Quote Reply
Posted: 24 July 2009 at 8:34pm |
It would be nice to repeat these tests with an aged cell. i.e. one that has 500 or 1000 cycles on it. To see if the charge cutoff voltage requirement changes with age.
Remember all the tests are being done on new cells. I know the old lead acid yellow tops required higher and higher end voltages on charge to reach the full recharge. Yes different chemistry, but I don't have a feel for Li chemistry in aging. Also, what effect has extremes of temperature on this charging voltage vs Ah ? |
Red Suzi
3PIM, the workhorse of industry and now the racehorse of transportation. |
Nevilleh
Quote Reply
Posted: 25 July 2009 at 6:50am |
Tesla claim that by reducing the charge voltage from 4.2 to 4.15, they lose 5% capacity. That's a big loss for such a small drop in voltage and it doesn't agree with what we are seeing with the TS cells.
Tritium_James
AEVA Member
Quote Reply
Posted: 25 July 2009 at 8:44am |
They're not using phosphate chemistry cells though, so that could make all the difference.
acmotor, the two cells I've run this test on so far aren't brand new, but probably only have about 50 cycles on them. They're a bit over two years old. I agree an older cell would be a useful test. |
Admin Group
Forum Admin Joined: 25 November 2007 Location: Perth, WA Online Status: Offline Posts: 1492 |
Quote Reply
Posted: 25 July 2009 at 3:08pm |
i have 14 cells that have done around 450 cycles at 1.4C continuous, 5C peak, with 8 overdischarge events.
I could lend a couple to each person for testing if you like (just need to pay postage)? these cells were manufactured 02 oct 2007, and i put them into service in Jan 2008. Matt |
http://www.evalbum.com/1499 http://www.evalbum.com/1809 |
Tritium_James
AEVA Member
Quote Reply
Posted: 25 July 2009 at 3:12pm |
Matt, thanks for the offer, but this power supply I have is going away mid - end of the week, so it's probably pushing things a bit to try and fit another test in before it goes.
Quote Reply
Posted: 02 February 2010 at 9:31pm |
shlodo
Joined: 14 March 2010 Online Status: Offline Posts: 14 |
Quote Reply
Posted: 14 March 2010 at 10:11pm |
Hi guys, great thread.
We are building an Electric SAE racer here at RMIT. We have 40AH Thundersky cells: Vnom=3.2V Vcharged=4.25V We have a battery management system on the cells (dont know the manufacturer) that warns you to stop charging cells at 3.8V (red led turns on). We have been disconnecting charger as soon as we see the warning light. Given the info in this thread, I'm concerned we undercharging the batteries. I've looked at the BMS system at EV Works their cells also warn you or activate a shunt at 3.65V. This doesn't seem right since TS cells have Vcharge=4.25V http://www.evworks.com.au/index.php?product=BMS-CM060-V6 Any thoughts guys? Is anyone familiar with the 40AH TS cells? Should we be charging the cells to a higher voltage? Cheers, Ben |
Admin Group
Quote Reply
Posted: 15 March 2010 at 3:48am |
in my experience, there is no advantage to taking TS cells above 3.5v
as long as you hold the cells above 3.5v until current falls to C/100, they will be fully charged. Matt |
Tritium_James
AEVA Member
Quote Reply
Posted: 15 March 2010 at 5:56am |
Ben,
The red light on your BMS might be turning on at 3.8, but what voltage is the balance resistor turning on at? If it's also turning on at 3.8, then you probably actually want to charge your pack at a much reduced rate when the first LED turns on, and keep charging until they are ALL on. This will give you a balanced pack. What the 'much reduced rate' is will depend on what balance current your BMS can do. |
shlodo
Quote Reply
Posted: 16 March 2010 at 10:48pm |
Thanks for your help guys
Im not sure what voltage the balance resistor activates. Or if it even works like that? I dont know enough about the BMS. We have been disconnecting the charger as soon as 1 red light comes on, so the pack is never being balanced properly. I will be in charge of the batteries this year and is why im keen to learn more about them. Could someone explain how most BMS systems actually work? |
Nevilleh
Quote Reply
Posted: 17 March 2010 at 4:19am |
BMS can mean "Battery Monitoring System" or "Battery Management System". In the former case, it merely monitors the cell voltages and perhaps temperatures and it may give a warning of some sort if a cell gets too high or too low in either of those.
The latter is a bit smarter in that it will have some form of balancing system, usually a load resistor across each cell that can be turned on or off by the controller. When the controller sees a cell at the fully charged voltage, it turns on the shunt resistor and so the charging current bypasses that cell but continues to flow into the others. This happens for the next cell and so on until all cells are at the correct charging voltage and therefore "balanced". At which point the charger shuts off. Note that the amount of current that can be bypassed is pretty small as it results in a lot of heat in the bypass shunt. For example, if you bypass 1A at say 4.2V, that's 4.2 watts per bypass resistor. If you have 45 cells to manage, there's a nice little heater! Another method of balancing is to simply shut off the charger when the first cell reaches max volts and then use the bypass resistors to bring each cell down to whatever voltage the lowest one is at. Doing it this way usually means you only need about 200 mA of bypass current per cell, but the cells will not be quite at full charge. The difference would appear to be very small though. Unless you have one cell that is very low compared with the others - then it brings them all down to that low level, but they will be balanced! And get better as they are cycled more - we hope. If you really want to balance a pack right at the start, then you should stick a 4.2V (or whatever) charger across each cell and make sure they are all at full charge before being put into service. Is your BMS turning on a red light for each cell? If it doesn't control the charger current, then it is most likely just showing that the cell has reached its charge voltage. It may indicate a shunt being turned on, but that is unlikely unless the charger current is down to an amp or so. Note also that the recommended charge voltage for Thunder Sky cells is 4.20V and the voltage for Sky Energy cells is 3.60V. Edited by Nevilleh - 17 March 2010 at 4:26am |
borrows123
Joined: 07 May 2010 Online Status: Offline Posts: 1 |
Quote Reply
Posted: 07 May 2010 at 5:44pm |
A charge-control unit was developed as part of a program to validate Li-ion cells packaged together in batteries for aerospace use. The lithium-ion cell charge- control unit will be useful to anyone who performs testing of battery cells for aerospace and non- aerospace uses and to anyone who manufacturers battery test equipment. This technology reduces the quantity of costly power supplies and independent channels that are needed for test programs in which multiple cells are tested. The cost savings that were achieved in a test program are shown in Figure 1. Battery test equipment manufacturers can integrate the technology into their battery test equipment as a method to manage charging of multiple cells in series.
BORROWS
Admin Group
Quote Reply
Posted: 08 May 2010 at 8:10pm |
welcome to the forum borrows
perhaps you missed a link? I see no figure 1. Matt |
| Forum Jump | Forum Home | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
